Alarm 10 when starting up
Hello all.
I recently converted my LM 2.5 over to the CLSM. Now every time I start up the LongMill, I have an alarm 10. I have checked the switch, and it is not depressed. I clear it by clicking the button, but when I do, the CNC won’t move when I use the direction arrows. The only way I can clear it is to unplug the switch, wait a minute, and plug it back in. Then clear the alarm again. I can then hear what I assume are fans in the new motors start, and then the machine will move with the arrows. I am sure there is something simple I am missing here; I am just not smart enough to figure it out. I am running gSender 1.5.5.
Thank you in advance for all your help.
Yes, this is a safety feature of the SLB-EXT that AltMill owners are familar with and CLSM kit owners should be soon.
You need to have cycled (depressed and released) the e-stop button before unlocking or movement will be prevented.
Generally a good workflow that’s worked for me is making sure the button is pressed down as I power on, immediately release the e-stop, then connect and unlock and proceed as normal.
All right that is good to know. I will start doing that. Thank you for your help.
