Auto Probe Issues
Got my Longmill MkII up and running and have completed my first jobs! The only problem I can’t get the probe to work. It’s being detected by the control board, I can see the led lighting up, but nothing is happening in GSender.
Phil
you need to reset your slb If the light is coming on but the popup button isn’t turning blue, this can sometimes be fixed by resetting your board settings. Do this by typing “$RST=$” into the console tab and hitting Enter, then use the power switch on the back of the board to “power-cycle” it off and back on again. Once you reconnect in gSender you can try probing again.
That solved it!
Thanks!
