Autozero not working for X
Recently, when I attempt to zero the X axis it fails. I can zero the Y and Z but not the X. When I attempt to zero the X axis, the spindle starts to move toward the left and will not stop until it errors out. I’ve rebooted my laptop, the Altmill. I can Autozero the Z and Y axis. Using the crosshair probe I’ve installed I can set the X axis zero.
@Jgt1942 How close to the left rail are you? Anything closer than about 45mm will generate Alarm 2
The left side of the board is 193mm from the left rail. As a test, I tried two different-sized boards; both failed.
A couple of days ago, I could use the AutoZero and zero all three (XYZ).
@Jgt1942 and that’s with the auto Zero touch plate, right?
When you say it moves left and doesn’t stop until you get an error, doesn’t it hit the aztp left wall?
Is your end mill coated? Maybe the electrical conductivity is affected by the coating.
