Cannot get X axis to move
Reposted here from the FB Group:
I’m hoping someone here has seen this problem and has a resolution. I’ve checked the forum and didn’t see anything unless I missed it. I’ve just finished assembling the Longmill and just trying to jog the axis. Initially nothing moved but I didn’t have the plugs in all the way which I remembered was a situation some of you had. I was finally able to jog Y and Z axis without issues and that allowed me to secure the Longmill down. I am still unable to move X axis. I thought maybe there was a mechanical issue so I used Y output to drive X axis back and forth with no problem. I also also used Y motor cable and plugged that into X motor so I know it’s not a cable issue. When I command a jog I can feel the X motor vibrate slightly.
I would hate to think it’s the electronics and rather it’s just a problem with UGS in some way. I looked at the dip switches on the back of the controller and they looked ok. I didn’t flip them back and forth which I maybe should’ve tried but ran out of play time.
Ironically I fix large scale CNC machines for a living but this little one has me guessing, but still a few things left to try. I thought about scoping the output to see what signals I’m getting and comparing it to another axis.
2 months later…
Since the above post I have flipped the dip switches back/forth and tried the 32 & 64 bit version of UGS. X&Y share the same feedrate setting and Y moves fine so I don’t think it’s a matter of bumping up the feedrate. I have the step size at 100mm and feedrate at 1000. If I move Y it moves 100mm. When I try to move X, the position moves and I get some vibration on the motor but that’s about it. As I posted initially it’s not mechanics because I can drive X axis no problem using Y output on the controller.
Looking for some help/suggestions.
Hi Tony. Welcome.
Since you hear the motor humming it sounds like it’s getting the signals. One thing I can think of is I remember reading that some people have had trouble with having the eccentrics adjusted so that the v-wheels are too tight on the rails, and having the anti-backlash blocks so tight that the screw cannot turn. There’s only one X motor so it can be overpowered. Go back and loosen the wheels and blocks. Let us know if it helped.
Bill
@Rokkin Tony: Just to get me over any confusion, you can jog the X, if you plug the X cable into one of the Y outputs on the controller, correct? So, it’s not a motor or cable issue.
Do you see 4 lights on your controller, one for each motor driver?
From what you are describing, it seems that the X driver is acting up. Keep in mind that I’m not anywhere close to an expert, nor do I play one on TV.
I’ve loosened the nuts and can rotate the axis by turning the screw with2 fingers so it’s not mechanical. If I swap the X and Z outputs the X runs fine but the Z does not. I’m convinced it is the controller as well. I’ve also tried to adjust the current level with no luck. I will talk to Sienci to see if I can get another controller.
Tony, it sounds like you’re tried all the combinations of switching cables, motors, etc. so I have to agree with Grant that it may be the controller. At this point I’d go to Chris and Andy to see if they have something else to try.
Yep…did that and I’m picking up another controller tomorrow. Thanks!
New controller in. Works like a charm.
@Rokkin Glad to hear things worked out, Tony. Have fun.
