Closed loop kit install issue
I have finished installation, but all movements on each axis is exaggerated by a significant amount. So, a 5mm movement actually goes 40mm. Am I missing an obvious setting in g-sender?
Did you make sure to update your steps/mm from 800 to 100 in the software section? That’d account for it being 8 times the expected movement like you’re seeing.
Resources provides a macro to run - but you can verify that $100-$102 are 100
Software Changes - CLSM Kit
Turns out I had loaded the macro but not run it. Thanks for the assist. All good for now.
