I have gSender installed on a Linux host. Is there a possibility to access my macros and my tool change code outside of gSender application? For example to edit the macros without a connection to grbl or to make a fast backup of all macro and toolchange code.
Macros and events are stored in .sender_rc in your home directory (so ~/.sender_rc). Itβs JSON format so should be pretty easily parseable if you want to edit it outside of the application.
