Update: I solved the first issue. It seems that the firmware changes in the written instructions and the youtube video assume that limit switches are installed. If they are not, as in my installation, there are other firmware settings that need to be changed.
Setup
gSender 1.4.10
LM running SLB
no limit switches
Vortex = closed loop
Rotary slider set to 4th axis
First time running with the closed loop motor. I figured that I would start easy with the rotary surfacing module.
Two issues:
- When the job first started, the router stayed in place in X while the material rotated several times before starting the actual cutting.
- Using the feed rate slider did nothing.
Attached is the diagnostic file.
diagnostics_12-12-2024_17-23-21.pdf (27.8 KB)
