I just purchased a LongMill and the standard touch plate. I am new to gSender and having an issue: When prompted to test the continuity before probing, gSender doesn’t detect any connection, even though the PRB light on the SuperLongBoard turns on when I make this connection, and gSender correctly probes if I turn off the connectivity test requirement in settings.
Is there something else I need to set up to make the connectivity test work?
I can keep the required test turned off and use gSender just fine, but I much prefer to have this safety feature.
Other notes (from reading through the forum): I am using grblHAL and have my firmware set to my machine.
