When running the OUTLINE function before running a job in Gsender, the speed is very slow. How do I adjust the speed?
Outline uses G0 for movement, so if you want to adjust the speed of outline you’d need to change the firmware value of the max feed for that axis ($110, $111, and $112) since those are used for G0 feed rates. The values might just be set too low.
