I’m running a Huanyang vfd and spindle. I can switch from spindle to laser seamlessly but when I try to switch back, the huanyang v1 is listed in the dropdown but the actual value appears to be default spindle. I have to reboot the SLB to get control of the spindle again. I’m not sure if this is a limitation on grblHAL, gsender, SLB or just User Head Failure.
This is a known firmware issue that should be fixed in the next firmware release which brings our board up to a more modern version of grblHAL.
