I think my power brick is dead
Kickstarter backer here. Finished building my machine maybe a month ago. Today I went down to find that the amber light on the power brick isn’t lighting up. The outlet and power strip are working fine, and I get a green light inside the control box when the USB cable is plugged into the laptop, but otherwise no indication of power. I cycled the power switch, re-seated both ends of all applicable cables, and nothing. Guessing either a bad cable or a bad power brick. What do I do from here?
edit: I’ve emailed them at hi@sienci.com
@atcodes was Andy able to sort you out on this?
