Jog controls not working
Jog controls not working. G-Sender connected. Can load file, Right side is greyed out. Flashed firmware.
Welcome to the group Ralph!
Did you flash the firmware trying to fix the problem? Or did flashing the firmware cause the problem? You don’t mention your machine type but if you have a LongMill Mk2 the original settings can be found here. EEPROM Settings - LongMill MK2 CNC
Is gSender showing any error or message about homing? What if anything is displayed in the console when you connect?
