I had a bit crash while running a program, it was so bad that it drove the router bit all the way through the spoil board and even moved the project board.
I immediately stopped the program but now when I turn the Longboard on, I can’t even jog the machine. It says to click here to unlock, but when I click it, nothing happens. How do I unlock the Longboard after a crash?
Not 100% sure, it will depend why it’s locked. If you hover over the alarm and the lock icon, it might tell you a bit more information.
One thing you might do (if you have not already) is power down the machine and manually turn the z axis to withdraw it to a safe height. After that, pop out the e-stop and power the machine on again.
If you’re really stuck, I’m sure Sienci support can get you sorted.
