Longmill MK2.5 with Gsender v1.4
Ok. I am at a complete loss here.
Longmill mk2.5
Running gsender 1.4 (no, I won’t update given issues people seem to have with the other versions.)
Issue. I ran many projects without issue.
Today, 2 carves in. Ready to start my third, i grab the zero touch plate to set the bit and suddenly the CNC isn’t registering to gsender.
I restart everything, computer, program, CNC. It registered, I went to move the router to again set the bit, it lags out. Then drops connection to the CNC.
No amount of restarts seem to connect to the machine.
I need your help!
*update* last total reset of all seems to work. Any idea what causes this
*uodate 2* it dropped the port. Wont reconnect. Please help!
@Forbius121 Welcome to the group.
If you are running gSender under Windows, and connecting via USB, I would start by ensuring that all the USB power saving settings are turned off. If that does not fix this, replace the USB cable.
I will try that first.
If you have the SLB (MK 2 does I think) then you could try to connect via the ethernet port, I find that to me a much more reliable connection.
