I am thinking of buying an Altmill 4x4. The things I want to make are guitars, furniture, cabinets, and carvings. I am currently proficient at fusion 360, blender and autocad(I do civil modeling for Trimble survey equipment and tractor machine control at work). I also have done alot of 3D printing. I am pretty good at starting from 0 and learning complex processes.
I am thinking of buying the Altmill 4x4, vortex, spindle, Autozero and some bits to get started. I have a Makita VC4710, a good computer for modeling and a 4k chromebook for Gsender. I have a spot I can add a legit dust collector in the future, I’m also considering an enclosure to manage noise and dust. I do have a hanging hepa filter already for fine dust.
It feels a little outrageousdropping nearly 5k to get started in CNC. Most of the things I am wanting to make are larger and I do think once I am up to speed I will use this alot. Talking with my SO she is supportive of me spending once to get a machine that will do everything I want.
My questions are
- Should I be considering something else to get started or is this a good plan?
- I have to run power to the machine is there a significant advantage to going to 220v route for the spindle? I was considering getting the 110v 1.5kw directly from sienci do you suggest something else? My interests are mostly cutting wood but I could see doing some aluminum for guitars and possibly some small survey instrument parts. I could also see drilling aluminum enclosures.
- Should I get the vortex from the start or add it later? I am thinking I would do carvings, legs and possibly guitar necks with it. I haven’t seen any guitar necks being done on one but it seems like it would be ideal. The longer size could do neck thrus even. I haven’t seen alot of videos showing it in action. Is it able to move along the X,Y and Z axis or does it lock out Y when using it? I can see advantages to being able to mill faces if it works on the Y axis also.
- For bits should I get the Altmill starter set or something else. AltMill Starter Set | Sienci Labs
Thank you for any feedback you have. I am looking forward to getting started with CNC.
