Hi All,
My machine has arrived (very excited) and I am trying to sort out my table top.
I have an existing workbench/island that is ~49" x 33" and I have some left over 3/4" MDF from a project. Looking at the PDF from the kickstarter page it looks like I should be able to get my MDF (42.5" x 60" piece) cut down to a size that encompasses the whole footprint of the machine less the controller. I am thinking of putting the MDF perpincicular to the long edge of the table top so that I can use the extra space on one side (left? does it matter) of the machine footprint to mount the control box (it just won’t be on the MDF, it will mount 3/4" lower to the table top).
I also have in my head that at some point I’d like to try some end grain joinery like I’ve seen done on the hobbycnc subreddit. To achieve that I’ll need some amount (4" - 6"?) of the actual cutting area to be cantilevered out over the edge of the underlying table so that I can vertically clamp work pieces for the end grain joinery work.
I haven’t been able to find the exact cutting area dimensions and whether they are on center on the frame or if the cutting area is offset in one or more directions. Can anyone advise on what they might recommend for the placement of the MDF top I’m going to make to mount the Longmill to (relative to the underlying tabletop dimensions) so I can achieve the 4"-6" of cutting area overhang for potential future joinery work? And still work safely?
The underlying table is an Ikea kitchen island and is quite sturdy so I’m pretty confident in it but I am concerned that the required cantilever may cause stability issues, something I definitely don’t want. On center it would be rock solid, but I don’t believe with an 8" over hang on either end of the table that I would have any/enough access to the cutting area.
Also, can someone advise which access the feet are the ~40.3" across vs the larger width which I think is about 43 5/8"?
Thanks in advance,
-Jeff
PS - I guess I should also ask what the observed Z-axis usable height is as I’ll to deduct the MDF thickness from that to determine the “joinery” usable height in the event the vertical work piece can’t come up through an opening in the spoil board (entirely likely, as that will limit length and isn’t really necessary).
