Made a sign....learned how to edit nodes
Took a pic at this place in Myrtl Beach. My buddy wanted a sign so I made…had to do a lot of tracing and node edit but learned a lot!
@beerbarrel Well done, Tracy.
The original looks kinda lame compared to your improved version. I love it. How did you manage the bite part.. Small mill or did you use a saw of some kind to get it pointy?
What cad did you use? Did you use some kind of rptrace function and needed to correct the result or did you trace the whole thing by hand?
Looking sharp!! Great translation of the original with a lot more character. Looks like good paint job as well. How did you do that?
Thx Eddie…I used a 1/8 compression bit. It did leave the corners a little rounded but I hit it with some sandpaper where I could to square up the inside corners. I used Inkscape to clean it up and trace the best I could.
Thx Alex…I cut the letters first painted them then glued them on…I cheated a little I guess. If you look at they S’s they look a little larger than the other letters but they are that way on the original sign.
Ah smart! You did a good job on lining them up in that case.
Looks great. You must has done an excellent job in Node editing because the outcome looks amazing. Good job.
