@Jasonmagee79, It took me a few tries with just one of the letters using MDF before i got the numbers right in Carveco Maker. It’s still not perfect on close inspection. I think it’s because my router moved slightly on one of the axes when I was changing bits.
I read somewhere that i can activate the motors before the tool change to ensure there is no movement. Will try that with the next one
As for a finish I have been using a product from Germany called Osmo. I use the clear gloss “3011”.
it is available on Amazon. Don’t let high gloss scare you it’s more like a satin.
I sand up to #320, apply the first coat like this guy and then additional applications I use a 6 inch orbital with a white pad, number of coats vary, 3-5 is my usual. Buff off with a micro fiber rag after each coat, the finish is amazing.
