Option not available per instructions
I am doing the final steps per the final steps link
I do not have this option in step e.
I do have the Scienci router, but that link is broken
In the Config->Spindle/Laser section the first toggle enables that tab.
Thanks, that worked. needs to be added to the instruction page
I looked closer at your second pic. Not sure if you can’t find something or if you’re reporting a broken link. If it’s the Sienci AutoSpin router resources your looking for…
I found this about Sienci spindles but I don’t know if it’s applicable to the Mk3 spindle kit. I might have missed it but I was unable to find a Mk3 spindle kit in the store.
For what it’s worth, it’s already part of the Spindle setup section inside the LongMill MK3 resources, step 4 is verifying that the spindle tab is enabled:
This is referenced in your screenshot - I’ll pass on that it should probably be re-ordered to have the spindle setup step before verifying it works.
We also have a AutoSpin setup wizard as part of Edge that will come to main and also turn it on automatically for user who went through that process.
