PLEASE HELP with E stop issues
My machine is locked out and will not move any direction. I have 2 lights on the Estop and when I try to reset it they will not go off.
estop photo.pdf (1.5 MB)
gsender photo.pdf (2.6 MB)
Hi Mike,
All I can think of is checking the wiring on the green connector for the e-stop at the SLB.
Check the colors of the wires are in the correct order and if they are making contact. Sometimes a wire might be fastened on the iosolator. Other than this, I cannot help for I have not an altmill.
Also check the e-stop trouble shoot page. Something might be there to help you out.
A section in this troubleshooting talks about bridging two pins with something conducting. The pins they are talking about are these:
Please read and follow the section on the page. It seems it covers the problem you are having and it helps determening if your estop is faulty or not.
