I have a DIY CNC Shied Arduino machine. Using gSender 1.0.5.
Trying to setup the Sienci XYZ probe. The probe is connected to pins GND and SCL, which I read is A5 on the Arduino.
The probe is in bottom left corner of bed. The Z probing works perfectly.
Both X and Y start to travel right or back when trying to probe. Of course, it errors after too much travel.
I tried probing with CNC3D Commander and it worked fine.
Any suggestions would be greatly appreciated.
Update. I’m back the next day and the Z no longer works on gSender All 3 axis still work on the other gcode sender. If it helps, the movement always seems the same: moves 3 jumps in wrong direction. Each jump appears larger than the previous.
