Profile cut off on right side
Have three models in a project that I use and then create a profile vector with software. Vector creates fine…looks great in software, but when I run on my machine it is close on the left side but drifts out on right side and leaves about 1/8 + material on right side of project I have to then remove by hand. Any ideas what I am doing wrong?
Hard to tell from your description but I’d try to redo your toolpaths. Remember that they are a point in time when they are created. Any changes or tweaks to the design will not be reflected in previously saved toolpaths.
@Woody5850 Welcome to the group.
If someone here is going to be able to help, you should post much more information, such as
  1. What CAD/CAM software did you use to create the profile vectors?
  2. What machine are you running?
  3. What code sender are you using?
  4. What post processor did you use in your CAM application?
  5. Is it only this project in which you are experiencing this problem?
