I am running the latest build of OSX (10.15.7) and have installed the latest version of Java 8 (build 1.8.0_261-b12) but when I run UGSPlatform the terminal outputs ‘Unable to find any JVMs matching version “1.8.0+”’
The app begins to load then a modal pops up with the heading “Nightly builds” then it crashes.
Haven’t been able to try out my Longmill yet as I can’t overcome this hurdle
@ryanprice I realize that the old longmill setup instructions refer to the august 2019 build. However, many here had problems with that, and there have been several updates. The most recent is October 2020. I have been using the August 2020 build with no issues at all, following a period of freezes with the august 2019 build. YMMV of course.
So I tried using the Aug2019 stable build and it can’t detect my longmill. I then downloaded the nightly builds Aug2020 and the classic version can’t find my longmill either. The Platform version manages to find the longmill, but when I try to jog the stepper on any axis there is no movement. I can hear the respective motors humming, but nothing moves. I can’t seem to find any info on next steps
@ryanprice Check your feed rate in the Jog Controller window. I think UGS defaults to like 1. Make it 1,000 then try 1 in the Z and XY step settings (mm settings).
Sorry - I updated the numbers above. I actually have 10,000 set on my feed rate in UGS - the LM won’t move that fast.
