Sensors installed/working but travel distance wrong
So installed my sensors as recommended changed my soft limits to 1276mm as recommended and changed the other to 860 mm. The machine seems to home ok but when I tell it to go to either back corner from the home position - it only moves 1212mm not the 1276. Also the soft limit I have set to 860mm for the other direction is only travelling 817mm. It does this consistently even with resets of software and machine.
Any ideas?
never mind, I just read that it will get you close - about 95% of the way and thats what they were designed to do. didn’t see in the docs but found it here
