Setting / Calibration Depth Left and Right
Is there a way to calibrate the depth of the unit from left to right? X Axis.
Doing some template cuts and when it works on the left side it will cut down through the material properly. but Far-right it will not cut through…
I have measured at the X access support bar left and right and the measurements match. and I have done the same with the X-axis Bar / Screw. both sides match.
Curious if there is something that I need to adjust slightly to adjust for this
Have you surfaces your waste board? If not, that should take care of your problem.
