Solution to skewed y axis travel
If you’re having an issue with skewed y axis travel, check the potentiometer settings. One of mine was off quite a bit and caused this problem! I think if we’re supposed to check and adjust dip switches and potentiometer settings, the back panel should be easily removable or the access slots should be much wider!
