I am just wiring in the shielded cable for my spindle. I have a braided ground shield which will be connected to the case of the plug at the spindle end. There is an extra wire in the bundle should I connect it to the ground shield? At the controller would I then be able to just use it for the ground, or would I still need to bind the shield braid?
If that seemed ambiguous, I have a 4 conductor shielded cable, I have 3 wires in use, what should I do with the 4th and the shield braid to ensure proper operation?
I am seeing lots of info but looking for a best practice that is know to be the most likely to work.
Thanx everyone
