Hey all, i’m fairly new to CNC’s and know very little about coding. The issue i’m having is that when i pause or stop a project to make adjustments ( to depth of cut for example) and want to start again from the line i stopped at, it seems the machine doesn’t read the previously set feed rate and cuts as fast as it possibly can. I’m sure this is a simple fix, i just don’t know enough about the machine yet and how to adjust it. I appreciate any help. Thanks in advance.
We’ve made some changes that should address this in an upcoming release - feed and speeds should be sent correctly on start from line in all situations.
Cheers,
Kevin
