Tool change error (Line overflow)
When I try a toolchange in gSender (latest - stable) I get an error 11: Line overflow in the console when I hit the button for initial probe. Is this a known problem?
When I try the EDGE version nothing happens when toolchange starts, the program just seems to hang.
Maybe I am doing something terribly wrong?
First off, welcome to the group @Mmb!
I think that more context is needed in order to help you.
Are you trying to do a tool change during a job (single file, multiple bits) or before the job starts?
What type of machine and probe device are you using?
Hey, I’ve got the same problem.
Configured gSender to “Fixed tool Sensor”, set the position of my tool length sensor. Created a small testfile in Fusion360, one file, two operations with different tools. Zeroed in on my non-existent workpiece and started the job. I get the Error 11: Line Overflow Error. Console output (from the line where it says that it overflows):
(T14) (M6)
ok
ok
ok
ok
feeder G4 P0.5
ok
feeder M5
ok
feeder ({"PROBE_THICKNESS_MM":30,"PROBE_DISTANCE":108,"PROBE_FEEDRATE":150,"PROBE_SLOW_FEEDRATE":75,"RETRACT":4,"XPOS":-0.002,"YPOS":0,"ZPOS":0,"PROBE_POS_X":-796.499,"PROBE_POS_Y":-737,"PROBE_POS_Z":0,"Z_SAFE_HEIGHT":-10,"UNITS":"G21","SPINDLE":"M5","DISTANCE":"G90"})
error:11 (Line overflow)
And the corresponding part of my gcode:
G90G94
G17
G21
T14 M6
S9549M3
G4 P2
G54
Tried a bunch of stuff and settings several times, a lot of times … the last 6 hours or so, no change.
The machine is self build running on grblHAL. I’ve also got a regular touch plate connected (which is working as intended)
Thanks in advance.
Freddy
Edit: I tried it in the latest stable and edge.
Should be fixed in the next release :+1:
Thanks.
I am using a printnc with grblhal controller and a “bitsetter like” fixed probe.
I tried all scenarios. Everytime the same error.
Just read that it will be fixed in the next release. That’s nice because I really like gsender. Nice work guys.
