I would really like to make my Spacebar and emergency stop/pause function in UGS. Is there an easy way to edit the keyboard mappings?
-Jeff
-Jeff
Jeff, you can make a stop function but it will not be a true E-stop function because movement will continue until the buffer is empty. For a true E-stop the best way is power the LongBoard and the router through an paddle-style E-Stop button. I use this one:
If you want a convenience pause/stop, go to Tools Options Keymap. Scroll down about 1/4 of the way into the Machine category. Select the STOP line, left click in the shortcut column and hit the spacebar. Remember it won’t stop movement immediately.
Bill
Great info, as always, thanks Bill!
