Me again. I note the two dimensions on the visualizer in UGS relate to the size of your material. What is the dimension on the far right as it always seems to be a little larger than my cutting depth?
I believe that it is the thickness of the material.
You may not be able to help here as I set the thickness in Carbide Create along with the Stock size. The thickness and cut depth don’t seem to correlate with the measurement in UGS but the stock size does.
Think I’ve figured it out. It seems to be the depth of your material plus your retract height.
