I have Vcarve pro and i created and saved a 3d project to my USB stick. When i take it to the Sienci computer and download it on the hard driver, it opens incorrectly and is off to one side of the X axis.
It was never doing this when i would use the USB stick before, but had other issues then like not carving correctly and destroying wood at random. Any ideas how to reset this.
@Nbase1 I’ve moved your question to the Vectric category, Nick.
It’s hard to say from your description exactly what the issue is, but since it starts with VCarvePro, this may be the best place for it.
When you say that it opens incorrectly on the second pc, are you opening it in VCarvePro on that PC, or do you mean that you are opening the gcode in gSender on the second pc?
If you post your .crv file, you may get better advice. If the model is copyrighted, don’t post it.
