Closed loop vortex on altmill current gsender. Vortex is rotating about 8x as much as it needs to. Cuts then keeps spinning forever before stepping over.
Did you verify the dip switches are correct on the motor?
I believe so. It’s currently on on on off on. (12345). Is that what you have? I did just run across something on travel resolution that I didn’t see yesterday. I’m going to run to the shop and see if that does the trick.
Yeah no luck. I’m getting about 6.5x revolutions when I tell it to rotate 360 degrees.
From the manual that looks correct for motor dip switches. I don’t have one myself yet. Did you open a support ticket? They are fairly quick in responding. Please let us know here if you find out what the issue finally is.
