As was discussed in a previous closed topic, I am having issues maintaining a connection on Windows 11 between g-sender and my MK2 30x30. I tried all the suggested solutions, but still canāt get in to stay connected. As soon as I start running a job or using the jogging feature, the connection fails after a few seconds. We have another laptop running Windows 10, and that one does not have this issue. We want to use the Windows 11 since this laptop is dedicated for the CNC. Thanks in advance
Hi there, Matt. Are you still having the connection issues? If so, can you walk me through what suggested solutions you have followed. Have you installed shielded connection cables between computer and CNC machine control box? Have you separated the power cable to your milling motor, from every other cable?
