Work not centering
I have an MK2 and I’m having a problem with cutting centered in the work space. I’m assuming it is a software/human error but I’m having a problem figuring it out and need a little help. I am using Vcarve and g sender and I have a AutoZero Touch Plate . It has been off but Until this latest project being centered did not matter because I was cutting the work piece. The project is always shifted to the right by about 1 inch in this case.
Any ideas?
Here is a picture of the project.
sign.pdf (656.2 KB)
The project ends up shifted and the butterfly on the right is part way off the board when I cut the project.
Basically the whole project is not centered.
@MikeH Pls post the .crv file, Mike.
gwilki it’s saying the file is to big to load. Do I need to do something to the file before I can load it?
Everything I make is shifted, It has to be a setting.
@MikeH What is saying that it is too big to load, Mike?
It’s saying the crv file is to large to load here.
@MikeH Gotcha. Sending a pm.
Big shout-out to Grant, thank you so much for the help Grant, problem solved.
