I’ve run this project about 4 time without issue. But now I am running into an issue. On the second pass it seems like the x axis has moved and I am getting a stepped cut . When I stop and reset to zero it is not online where the first pass is.
Hello @Aantaya, welcome to the forum.
I am going to assume that you have a LongMill but maybe my suggestions might apply to other machines as well. Seeing that you have run the job successfully before I’m thinking that it probably isn’t software related. I would check that everything on the X axis is tight, especially the coupler from the x axis motor to the lead screw. I had an x axis problem that was because that coupler was a little loose and would slip under load.
Thanks for the suggestion I’ll take a look
Did you find a solution to this problem? This is the same issue I am having right now.
Assuming your work holding is sufficient, lost steps
are usually mechanical. Make sure your v-wheels and anti backlash nuts aren’t too tight.
