After assembly downloaded gsender to test out jogging machine. Machine will not move in any direction. The step motors spin but lead screws don’t turn to move the router.
Hi Joe! If you’re positive the steppers are turning, I would double check that the couplers are all tight. That would be the only possible problem I can think of.
Thank you i will give that a try.
