X Zero keeps changing
Hi,
Using gsender, have zero’ed all axis.
The X doesn’t seem to hold the zero, meaning each time I zero it, on the same stock just to check, the zero is off my a 1/4 or so.
I zero the X again, then check it, the machine is off 1/4 again.
What’s going on?
TIA!
I just noticed, when I press GO TO ZERO X, it doesn’t move fully and seems stuck and makes a bit of noise, but if I jog it manually with gsender in X direction, no issues at all.
Related?
Are you cutting between the zeroing operations?
The x axis thread came out from the motor side, hence was all wrong each time, and hence the noises.
All fixed after I tightened it all.
Glad to hear it, @Bizbrar
