Z axis jog w/soft limits enabled
When holding down the Z axis jog button with soft limits enabled, the lead screw for the Z axis only turns at about two revolutions per minute. Also, after releasing the Z jog button on the gsender panel, the lead screw continues to rotate at about two revolutions/minute, and the only way I can stop it is by hitting the emergency stop button on the machine. X and Y jog works fine with soft limits enabled. After disabling soft limits, the Z axis jog works as it should. Z axis travel is set to 60mm, which is correct for my Masuter Pro. I have another issue which may be related, but I think if I fix this, the other issue will vanish. Any ideas?
