I am having a difficulty getting the Z-Axis to go onto the X-Axis, even with the eccentric nuts at the highest position, HELP!!!
@DrewS - Did you mean Z onto the X? Or X onto the Y? Try removing all of the X wheels and take a small round file to remove the paint from inside the mounting holes. Then remount the wheels. That should loosen up the eccentric nuts. Don’t file too much. Just enough to remove the paint. Also just loosening the bottom wheels might help then retighten after mounting on the Y rails.
My bad, I meant the Z onto the X! It appears that I got a aluminum extrusion that was a little bit off spec. The good people at SeinciLabs are doing a great job at sending out a replacement!!
