Hi, been using .73 for a few days, like the software alot, just noticed a bug, when I update the thickness of my z-probe, it shows it in the settings, but when I do the actual probe, it still using old value before I changed it… also, when I delete a numeric field, it automatically adds a ‘0’, which is kinda annoying… eg, default value is 15 mm plus 4mm offset, even though I changed zprobe thickness to 20mm, after probe is done, it shows z height of 19mm, but go back into settings and it shows thickness as 20mm… hmm
Thanks for the report!
This should be fixed in the next build.
Cheers,
Kevin
