Sorry, I just realized I should have replied to your comment about the topic.
It hasnāt been implemented yet, but has remained high on the list of features weād like to implement. Glad to know thereās one more vote of interest ![]()
Weāre going through a gSender redesign right now since we want to do our best in addressing the remaining beginner-focused issues that are commonly reported so that we can finish gaining confidence that gSender has basically reached the max amount of accommodation for green CNCers. Then shortly afterwards weāll be able to have some fun coming out with some more advanced features like this and some others that are also high on the list
Glad to hear! I second or third the request for autoleveling functionality. Iāll throw into the mix that it would be great to have different zones that could remain in memory. For example, put 4 different circuit boards down in different XY locations on the table, have them all automatically Z height probed, then when gcode is loaded, apply those height maps to the different āzones,ā in this case, boards. This would be ideal for those of use running many boards at a time.
Cheers,
Tyler
Any news on that? I would like to use gSender in my projects but without this feature its impossible for me.
Same here! I really like this app but canāt use it for the same reason: I mainly mill PCBs and cannot do it without a height map feature (similar to the one in grblcontrol (candle)).
Shame, gSender looks so much better and easier to use.
EDIT: NVM.. I didnāt comprehend the original reply. It wasnāt on height map but feed rates.
Height mapping shows the Z height differences between areas of the work surface.
For instance, I have a homebuilt CNC using GRBL and an arduino.
Unfortunately, the bottom left is about 0.6mm higher than the top right.
A height map would compensate for this.
This is most commonly used in the 3D printing world as auto-level.
Same request for me. I love Gsender but canāt use it just because the surface mapping is missingā¦
Now that I have read through this topic I too feel this feature would lure me out of my v1.2 bunker and install the version of gsender that would offer this.
I want this, I need this. In fact I canāt think of anything elSQUIRREL!
Thank you for the 1.5.2 upgrade, love continius jogging and the new look!
Now just add height mapping for PCB milling and such work and it will become the killer app it deserves!
Also looking for Height map feature.
Pretty much mandatory feature when milling PCBās.
I donāt quite get why this is necessary when the very first thing you should do is to surface your wasteboard which should result in no z variation that would need to be mapped.
You canāt surface a PCB. Even if the surface underneath the PCB is perfectly flat, the PCB itself is not. At the same time, you need to remove only a very thin top layer ā about 35-40 microns.
Thatās why even the slightest unevenness can result in missing or incomplete traces on the board. A height map is a mandatory step in PCB manufacturing.
I realize you canāt surface a PCB but if the surface underneath the PCB is a vacuum table then the PCB should in fact be flat for the milling procedure. This is on my long term bucket list. It is unlikely that milling with our level of equipment will only mill away the copper but I donāt see an issue with a tiny bit of the board itself being milled away with the copper.
If tape thickness is consistent than maybe double sided tape could be used for holding the PCB?
Anyhow, I am not there yet ⦠but it is on the horizon.
Thanks for considering it.
It is a quite common feature for gcode senders dealing with PCB milling.
I get your idea with the vacuum table, but most often than not is a feasible feature for the machine used and it still does not cover the manufacture differences seen within PCBās.
For reference, when creating isolation paths in the copper you want them to be as clean as possible and as small as possible. The height maps helps a lot with that, making sure a v-bit maintain a close to constant depth within the substract.
Donāt have at hand but can share the different it makes milling with and without a weight map PCBs that were firmly secured to a flat bed with double side tape.
Gotcha. I did not realize that there could be manufacturing differences within a PCB. Somehow or other I was under the impression that a PCB was a precision product.
When you have a chance, I would appreciate you posting the pictures of work done with and without the height map setup.
Te way PCBās normaly being produced does nor require the degree of precision that milling with a V-bit neither does laser way of prototyping boards.
Someone recommended this software, and i looks really good, but I need heihtmapping for what I use my cnc. I saw that there was a topic about it, but would like to know if there is any new information about this funcionality
Height mapping is not yet available but I believe it might be on the list of future improvements.
Iāll wait for it then. The software appears to be amazing, I really want to try it out
I think itās been on the back burner for close on 2 years so I donāt think itās a priority. I use other software if I need to height map for eg. pcbs.
