SLB Setup on Custom-built, Non-Sienci, ZYYX CNC Machines
Ohhh, 3200 pulses/rev is a lot different! Most stepper motors have 200 steps per revolution, so 3200/200= 16 microstepping. The SLB is set up for 32 microstepping by default so that means you’ll get even more detail on the SLB but you’re right there is a point you get to where the level of detail coming from the motors has diminishing returns. With 32 microstepping on a 8mm lead, lead screw, that means that there will be 800 steps/mm of machine movement, meaning that the theoretical movement accuracy of the LongMill becomes 1/800= 0.00125mm or 0.0000492" which is just an unbelievably small amount for most hobby applications and is likely not able to be hit by any hobby machine realistically because of other sources of error from the machine mechanics.
Enjoy your time away! :+1:
I probably knew some of that when I originally was building my machine about three years ago. It vaguely rings a bell. Thank you for the refresher course.
As rigid as I have tried to make my build, I am nowhere close to that level of detail, as you said. It will be interesting to see if my aluminum jobs end up smoother. I don’t think I will see too much difference in things milled from wood and epoxy.
Thanks for the conversation. I am sure there will be more to come when I am back.
I have returned from my trip, and have been able to start to address the issue of machine calibration.
The settings for $100, $101 and $102 set to =200 was way off for my steppers and 1605 ball screws. All three of the axis on my machine use 1605 ball screws. So, the values for $100, $101, and $102 should be very close, but I will test for each axis.
After several trial and error values for $100, I have narrowed it to 321.4 using 100mm as a reference distance. I will be testing a larger distance to check the precision before I cut the first job using the SLB.
The issue I ran into setting these to this higher value is the stepper would fail at the default jog speed of 3000mm/min. Through trial and error I was able to run my tests at 2600mm/min. So, I change Max speed for X to $120 = 2600.
So, not the zippy 5000mm/min. of the default setting for the SLB. I am also concerned if I will be losing steps under load when actually cutting material.
Can Acceleration be lowered to compensate for this?
I love the way the SLB operates, and all the advantages it offers over the Arduino controller I had been using, but this is at the heart of my initial concern of switching to the SLB. Going from external stepper drivers that allowed for more current to the on-board drivers that are close, but less than the current I was using for my steppers.
One issue of concern, while I conduct calibration on the YY axis, has come about. Although the two steppers on this axis are from the same batch, over time, one may have become weaker than the other. While testing accuracy at 500mm, I have twice forgotten to reset the jog speed down to 2000mm/min. This has resulted in the left motor failing while the right turns. Obviously a scary situation that requires me to stop the trial immediately. I think I can operate within a tolerance to avoid this while milling, but I am not super confident given the fact that this has occurred.
Any recommendations?
@stoddad to answer your question, if the motors were stalling near the beginning of the jogging motion, then it’s more likely originating from acceleration settings that were too high instead of max speed. In that case, if you reduce acceleration then you should be able to bring max speed back up higher. I’m also doing some testing right now on an area of the SLB I realized I could teak to potentially get more power output from the drivers to the motors but that testing is still a WIP
For your Y-axia binding setup, I’d recommend also looking at acceleration and max speed so you can ensure that you don’t run into edge cases where one gets stuck up and the other doesn’t. In future, there are other things the SLB should theoretically be capable of that are yet untested which may also be able to help keep track of things like this :saluting_face:
Chris, Thanks for the feedback.
I had lowered the acceleration, so it is good to have that idea reaffirmed. I have not raised the default speed to test it, but I will do that. I am currently resurfacing my waste board. Since this pushes the X and Ys to there limits area-wise, and I am using a 1" surfacing bit that can hit some drag when there is a high spot, it might be good for testing speed.
As I get closer to normal operation with my machine, I am generally happy with switching from my previous control system. I like the features and easy of use of gSender and the SLB. I look forward to what you discover, as you develop both.
I did run into a strange thing while zeroing the axis and setting up for surfacing. I was try to return my X to Zero, so I clicked the Go To (blue box) next to Zero X in gSender (or at least that is what I was trying to do). My Z axis started climbing (quickly). I pushed the E-stop, and have been manually jogging back to Zero from then on out of concern. I didn’t try testing this again. Should that button take the axis back to Zero, or does it have another purpose?
Thanks again.
If you go to Settings → Safety → Safe Height and that value is something that isn’t zero, then it will cause those buttons to move in Z before moving in X or Y so that’s probably what you encountered. If you set to 0 it should eliminate that type of movement
Great report back, glad to hear you’re enjoying your transition over!
I have successfully set up the SLB as my controller, and have it working consistently with my custom YYXZ CNC Router. I am turning my attention production set ups.
Setting up the SLB for my machine had a little bit of a learning curve because I switched from CNCjs to gSender. I also changed my CAM from Carbide Create to Fusion 360. I taught 3D using Maya and other Autodesk apps. I was never a big fan of Autodesk’s approach to modeling and user interface. Switching to Fusion, after being away from Autodesk – reminds me of many issues I had learning Maya. I hated Blender at one point, but they have listened and addressed a lot of complaints over the past 7 years - it is solid and pretty easy to pick up now - if they only had a decent CAM plugin. I wish Autodesk would make some radical interface changes to make things more intuitive. So, getting up and running again has taken several weeks longer than I would have liked. Having said that, I used Fusion on my custom CNC machine with the SLB and gSender for control to produce a 2 sided milling job that requires some precision.
The purpose of this thread is to address issues with custom machines switching to the SLB. With this in mind, here are the things I am now trying to understand that might fall under that category.
WCS Questions
Fusion likes to use workspace coordinates, and it would be easiest for repeatable task I need to do (carving guitar bodies) to set the default workspace coordinates to a specific location that is not the homing location. I am having difficulty finding information about changing this using gSender. I have searched the documentation, but do not see information for changing or setting G54 (or the other WCS setting G55-G59).
Is this something that is different in grblHAL, needs to be done by loading a macro each time, or can this done in firmware?
Would this be what you’re looking for? Additional Features - gSender Docs
Yes, it is. Thanks Chris.
I did notice this earlier in my transition to the SLB and gSender, but I had forgotten where it was. I remember thinking the convenience of it in the gSender interface was great. My searches referencing G54 (and other GXX codes) didn’t find this page. Your documentation is concise and thorough. So, it was odd not to find it. Cross reference G54 (and other Gxx and GRBL codes) in your search engine would be good, if possible. I was likely looking at it in firmware set up, but I think I searched other documentation, as well.
I do research these apparently obvious and easy questions before posting here. I am aware that you guys have a lot to do, and I try not to add to that needlessly. So, thanks again for the quick answer!
David
That’s a good point @stoddad! I think I’ll update that section to note the technical codes so people can still find it if they’re looking. Just tried it myself and it didn’t pop up so it’s good feedback
EDIT: ok it’s in there now and seems to at least be showing up on the Resources searchbar. Hopefully once the crawler bots come around it’ll show on google too
