Good day! I just installed the SLB, and 2 issues came up:
- Auto touch probe is not working on X and Y axis (good on Z axis though). Makes a grinding noise when trying X or Y, then gives an error message.
- I have an existing nc file, but SLB is not cutting correctly (works on the original board). X axis cut is appr. 18 inches wide, but SLB is only cutting 6 inches - so the cuts are intersecting with other (like it compressed the cuts together). I’m using Easel to create the gcode, and as I mentioned earlier, when going back to the original board, everything works. Weird!
