Hi, I was wondering if there’s any plan on the roadmap to support 3D touch probing for faster and more flexible workpiece indication.
3d probing works , you can select all 3 axis and use the small chineze probe, i used a relay in between the probe and the board, i had one board burned out, probably due to miss wiring, or the probe releases a small current on the switch side, idk, but i didn’t what to burn the second one so i added a relay
