46282-k Help Setup
I haven’t found any useful information on how to set this bit up in Carveco. It does not accept the tool file like Vetrics. Do my settings look correct? There’s no Tapered Ball Nose in the dropdown to select, but ball nose doesn’t have the radius and angle settings to fill out.
@Chaosweaver Your dimensions look good. What are you planning to do with it? For finishing carving on 3D carves, the stepover may be a bit big.
Did these two with that bit, but I had multiple tool files for the same bit that I created, so just wanted to make sure. The bear and the dragon thing are about the same size, the bear took 12 hours, the dragon took an hour. I have a good idea of what stepover produces what now.
