A more complete MillOne custom synth
So I’ve been working on a new custom synth. Today was a pretty big milestone as it all came together. The last bit was milling ā€œmodel dā€ into the backplate. Quite a bit of this synth body was built with my ā€œbeautiful ā€œ MillOne.
I found that Fusion 360 kept destroying my work with weird ā€œJob finished, hey let’s go to Z0 and then buzz to X0Y0ā€. So I’m hand changing the file to ā€œ let’s be sensible and go to Z15 and then go to X0Y0 and then go to Z0ā€. Same on start. It goes Z0 then to the XY where the job starts, I revise that ā€œZ15 the first plunge cut position. I know, Z0 shouldn’t touch the work surface if it’s at stock top, but Programmer world and Real world are different so I like to play it safe as alu isn’t free.
Anyhow the MillOne is a blast and it’s something that’s actually made in Canada! I’m saving for a LongMill.
@tuejan That is awesome work, Nik!
Check your ā€˜Safe Retracts’ setting in your Gcode programs for Fusion. I recently posted screenshots for this on someone else’s thread - it should not be G28 which is fusion’s default.
Wow it’s really beautiful Nik. Both the machine but even moreso the syth :cry:
Hi, yeah i think i saw that thread. So i already checked safe retracts is set to clearance height. My setyup is
Bottom Height Selected contours Offset = 0
Top Height Stocktop Offset = 0 (stock is same as model top in this instance)
Feed Height = Top Height Offset 5
Retract height = stock Top Offset = 5 (so same as feed so probably wrong but not related)
Clearance height = Retract height offset 10mn
So for my 2dpocket its showing Top 0mm, retract 5mm feed 5mm Clearance 15mm
