Ask others in the community for help if you’ve reached any stumbling points while assembling your machine.
Assembling MK2 for student and Z-axis moves backwards.  Wiring looks correct but router moves backwards up and down.  I’ve built several for students and customers but never had this problem before.  Help !  I’m at students shop now.
Thanks !  Dr Mike
I am assembling my Vortex to my longmill.
When I try to assemble the alignment piece (with the limit switch) to the headstock body it will only go up so that the alignment piece is .375 below the headstock body???
That is because the slots in the body of the alignment piece are on the heads of the bolts holding the motor assembly on.
What am I doing wrong???
John
