A few days ago I was working on my CNC and I accidentally pressed the X to close gSender.
The program has closed and processing has stopped.
Is there a possibility to add a check on accidental closing of the program, especially while it is running?
gSender 1.4.8
Thank you
Is there a way to lock gSender so idiots like me do not close it during a very expensive carve?
There are a few ways you can acomplish this.
colapse g-sender to have it not on screen. This is pretty useless, but it does do the trick somewhat.
Turn of your mouse or disconnect it from your computer.
Have a main computer at the machine and work only on a secondary one via remote g-sender. I believe you can close the remote without disturbing the main g-sender at work.
@Swinly Are you running gSender in Windows? There is a free application called NoClose. Using a hotkey, it disables the x in the upper right hand corner of windows applications. I’ve not used it, so read up on it. If you search “how do I prevent users from accidentally closing windows applications”, you will find other options.
A bit of a thread necro, but the next Edge release (1.6.0-Edge-3) will add a config option to prompt on application close so people can choose to have that peace of mind and avoid accidentally gSender.
