I would like to add 2 more inductive sensors (back left Y-Axis and Right side X-Axis).
I know I can use soft limits but recently started working with offsets and wasn’t thinking when I added a Y750 command to the console to move the gantry to the rear, so that I can have access to the work surface and the CNC crashed into the rear. Totally my fault but I would like to try and eliminate this type of error.
I have the MK1 V2 and am using the inductive sensors. I see that there is a second set of connection that appear to allow this. If it is possible, does Sienci have instructions on how to add the additional sensors? Is an additional power source needed?
Or is it possible to add a 2nd Y and a 2nd X and join them with a pigtail and have them go into the white JST connectors labeled as XLim, YLim?
